Called to the above machine, not draining.
Easy I thought when taking the call!
Pump refused to run, it turns out I am not getting a neutral back from the control board. The loom metres out OK.
Is there any reason other than a fault on the PCB that could be causing this.
The customer has some builders in and thinks they put it outside (covered) in the pouring rain) which could be the cause.
I am almost certain this has to the the PCB but at a cost of £373.08 (don’t you love Miele prices) I want to be 110{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure.
