Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Miele Fridge Freezer Parts Help
- This topic has 11 replies, 5 voices, and was last updated 3 years ago by
Batfink_uk.
April 3, 2023 at 11:33 am #101859
Batfink_uk
ParticipantHi,
I have a Miele Fridge Freezer (KFN 8462 S Index 20D 164) and the freezer doesn’t seem to be getting up to temperature (fluctuating but never really going lower than -9).
So I was looking to just get some part numbers for the following:
Evaporator Sensor
Temperature Sensor
Thanks for any assistance
April 3, 2023 at 1:15 pm #486468kwatt
KeymasterMiele spares or at least, most of them, you can only get from Miele now as they have stoped third parties getting access to parts as well as info now so, you’re at their mercy completely.
As we reported here:
https://www.ukwhitegoods.co.uk/appliance-industry-news/4424-right-to-repair-effectiveness
April 3, 2023 at 2:35 pm #486469Batfink_uk
ParticipantThanks for the response, I didn’t realise Miele had done that.
I have found the number for the Freezer thermostat as it’s a Liebherr part anyway and ordered that from Ebay, just need the Evaporator number and then I can see if one of those is on Ebay too.
CheersApril 3, 2023 at 6:35 pm #486470don
ModeratorI have in the past taken the Miele part number and had a Google. Sometimes it does work, the part number is usually printed on the part itself.
Don
April 3, 2023 at 6:39 pm #486471tubafan
ParticipantAssume the compressor is cutting out before it gets down to temperature, as if it’s running continuously and is still too warm then it’s more likely to be a refrigeration system fault rather than a sensor or thermostat one?
April 4, 2023 at 7:30 am #486472Batfink_uk
Participanttubafan, if that was the case wouldn’t the fridge not go to temperature too?
April 4, 2023 at 9:18 am #486473tubafan
ParticipantThe fridge only has to get down to about +3C so I imagine it could attain that even if the freezer can’t get down to -18C.
April 4, 2023 at 9:38 am #486474Batfink_uk
Participanttubafan wrote:The fridge only has to get down to about +3C so I imagine it could attain that even if the freezer can’t get down to -18C.
Yes makes sense. Thanks
April 4, 2023 at 3:01 pm #486475Tony R
ParticipantI would firstly check for any frost build up in the freezer, the issue does not sound like a sensor issue, and both sensor replacements for the freezer air and evaporator are identical, assuming the one bought already is the kit type replacement with crimps and a box. Also check the freezer fan operates, close the door and you should see it slowing down by opening the door and quickly looking at the blades in top centre of rear wall panel.
April 5, 2023 at 7:30 am #486476Batfink_uk
ParticipantTony R wrote:I would firstly check for any frost build up in the freezer, the issue does not sound like a sensor issue, and both sensor replacements for the freezer air and evaporator are identical, assuming the one bought already is the kit type replacement with crimps and a box. Also check the freezer fan operates, close the door and you should see it slowing down by opening the door and quickly looking at the blades in top centre of rear wall panel.
Tony R – There was a little frost build up but not much at all. I’ll check the fan, although the last time I had a look I could hear what sounded like the fan running until I opened the door then it stops as normal, but it’s definitely not running all the time.
The kit is the proper one with the crimp connectors and box.
I have felt the compressor and it’s pretty warm but not what I would call hot.
April 5, 2023 at 10:32 am #486477Tony R
ParticipantHi, you really need to remove the rear back panel to check for over icing, any excess will prevent air circulation and hence a high temperature display.
April 5, 2023 at 12:17 pm #486478Batfink_uk
ParticipantTony R wrote:Hi, you really need to remove the rear back panel to check for over icing, any excess will prevent air circulation and hence a high temperature display.
Hi, when I mentioned there was very minor frosting over some parts of the evaporator that was looking at it with the backplate removed.
