Miele G 638 plus diswasher
  • #53952
    Micky 32
    The machine fills, not the best pressure but ok. When it fills it starts up. You then hear the soapbox and after a minute or so it stops with the inlet/drain light flashing. It’s definately not a drain problem as it empties perfectly. My main suspect is the flow sensor, however the fact it starts up kinda puzzles me because i thought if the machine thought there wasn’t enough water would it start washing? Anyone else come across this fault?
    #317850
    gegsy
    Re: Miele G 638 plus diswasher
    IIRC try checking the recirc pump assembly and the little pressure switch attached to it for blockages 😀
    Micky 32
    Well Gegsy you were in the right area anyway 😆 . Checked but no blockages, very clean. However when i blew into the pressure switch it won’t click..thanks for the reply.
    #317852
    Seamy
    Hows it going in Longford?
    Would be a help if you could know which fault code it was as F06, F07 & F08 will all flash inlet/outlet led. Likely its a dodgy flowmeter, there was a problem with them not seating correctly & sticking.
    #317853
    Micky 32
    Are you from near Longford?? This machine doesn’t have a display and the inlet light flashes constantly. The pressure switch is definately faulty as it seems stuck and won’t click when you blow into it.
    #317854
    Seamy
    Micky i’m from Fermanagh, pressure sw’ is likely just very hard to make click by blowing in to it.
    Circulation pump motor may have a blockage on the impellor & it can’t get up required pressure to cause pressure sw’ to activate. Circulation pump is easilly split to check this.
    I know it doesn’t have display but if you go into service mode you can check fault codes.
    Common problems are flowmeters incorrectly seated or plastic paper restriction on circulation pump impellor.
    #317855
    Micky 32
    Not too familiar with this machine. How do you retrieve the fault code on this machine?
    #317856
    Seamy
    sent you a PM as theres no e-mail address listed
