miele g 653 scvi plus not filling Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › miele g 653 scvi plus not filling This topic has 3 replies, 3 voices, and was last updated 12 years, 2 months ago by mike100. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts January 28, 2014 at 12:35 pm #79240 mike100Participant starts to fill for about 2 or 3 seconds then stops and inlet/ drain light flashes. checked base which is completely dry. drain pump works fine. any ideas on this problem please. thanks, Mike January 28, 2014 at 4:26 pm #408547 SeamyParticipant Re: miele g 653 scvi plus not filling Most likely the water counter/ flow meter magnet or reed switch is problematic. PM me your e-mail address & i’ll send you the service manual if you need it. January 28, 2014 at 7:09 pm #408548 mike100Participant Re: miele g 653 scvi plus not filling Thanks Seamy, would appreciate that. Was about to buy aquastop hose. mikecolenutt@btinternet.com Mike January 28, 2014 at 8:27 pm #408549 jag-12Participant Re: miele g 653 scvi plus not filling Also check the wiring from the flowmeter to the module. Have had a couple with the wires broken under the door Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
