Miele G 679 Dishwasher
  • #58860
    DDDave
    I called to this machine today and found all the lights flashing. Is this a fault code ?? How is it read ?? I found the drain pump was blocked but any time I tried to select a prog all the lights started flashing. Help please.
    #335929
    Seamy
    Re: Miele G 679 Dishwasher
    All lights lit means theres been a fault ( pump blocked ) in your case..
    you now need to delete the fault code, think this is how you do it —
    Open door& switch off-
    Press & hold buttons 1 & 3 together
    Switch on & release the buttons
    Salt & programme button 2 will flash
    Switch off
    #335930
    DDDave
    Thats what I need.
    Many thanks Seamy, I will go back tomorrow and let you know.
    #335931
    DDDave
    Still got a problem. I did as Seamy said , turned it on and all lights flash again. I tried resetting again and now lights 1,4 and 5 stay on and 2 and salt flash. Any ideas please.
    #335932
    DDDave
    Any help please ??
    #335933
    DDDave
    bump
    #335934
    DDDave
    I found the way to unlock this machine.
    Open door and switch off machine.
    Press buttons 2 and 3 and turn on.
    Press solo botton twice and turn off.
    Turn on.
    That has unlocked the prog but now the machine turns on , drains and fills for 2 seconds and then stops with the selected prog light flashine. I have tested the flow meter , its ok.
    Any ideas please ??
