Miele G 975 SC plus inlet outlet
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Miele G 975 SC plus inlet outlet
  • #85157
    Shaneclare
    Hi, I hope someone can help.
    We went on holiday and returned a few weeks later and our dishwasher will not work the inlet/outlet just flashes. I noticed on the internet that this appears to be a fairly common problem with miele dishwashers.
    To explain what happens:
    I turn the dishwasher on, select a program and then press start.
    Firstly the dishwasher drains, it then starts to fill and after about 3 seconds it stops, it then restarts filling for about 3 seconds again, it keeps doing this until it reaches what I assume to be the correct level (about 2.5cm of water across the bottom of the unit) and then nothing. After a period the inlet outlet light starts flashing.
    So far I done the following:
    Cleaned all filters and hoses
    Removed the evacuation pump and cleaned, the non return ball is not stuck
    Replaced the thermostat in the base on the unit
    Used the miele tool to check that the main pump impeller is free, which it is
    Checked the float switch at the base of the unit it is fine
    Removed as many electrical connections as I can see from the bottom and refitted them
    Any further thoughts, I’m at my wits end, water in flowing in but something is stopping it from producing a continuous flow.
    I’m reasonably handy so happy to try most jobs.
    I look forward to some ideas.
    Regards
    Shane
    #427879
    Seamy
    Re: Miele G 975 SC plus inlet outlet
    On the side tank there’s a flow-meter, a wheel spins with the water & a magnet on the wheel should send pulses via a reed switch on the little p.c.b attached, to the circuit board to count the amount of water that has filled. If the wheel is not turning or the p.c.b has moved to far away it may not be picking up the pulses.
    #427880
    Shaneclare
    Thanks, I will check it out.
    #427881
    jameskirby
    Sounds like mine now, did you fix it?
