The rinse, dry and end lights (as described in the user manual), are all flashing at the end of the cycle. I would describe them as the progress lights. This only happens intermittently. I am guessing from the little info that I can glean, that there may be a leak somewhere that is activating the anti flood switch intermittently? Any ideas please fellas? Cheers. Steve.
Morning Steve,
Might be worth checking the wash motor impeller for blockages, that stops a pressure switch being activated and starts the lights flashing.
Had the same symptoms a while back and was kindly helped on here 😀
Regards, Ray
