Miele G1143SC Dishwasher
  • #95524
    WhiteVanMan1
    The dishwasher fills to what appears to be the right level, then stops and starts for a few times, then stops and the start/rinse/end led’s all flash. Any ideas please? I am suspecting a pressure switch problem. Cheers. Steve.
    #460607
    there is a pressure switch on the main pump that detects water pressure of the pump outlet. Am guessing a bit but sounds likely
    WhiteVanMan1
    Cheers Dave. I know these machines detect pressure to the spray arms. Here’s hoping it’s just blocked šŸ™‚
    #460609
    this might be worth a look. its for American machines but cant see them inventing a new system just for the states
    https://www.manualslib.com/manual/801663/Miele-G1000.html?page=2#manual
    #460610
    thedoood
    I’d agree with Dave..pressure switch mounted on circ motor..gets gunged up…I tried cleaning it out once..but had to get new one for same error as yours..
    #460611
    baron
    Or simply, you have inside impelor some plastik bags pieces or other things… which reduce water pressure flow…
    #460612
    WhiteVanMan1
    Cheers all for your assistance. I had checked for possible blockages. When I told the customer the pric of a pressure switch they decided to buy a new dishwasher . Steve.
