Guy, anyone help with this – yet another Miele dishwasher !
Three years old, absolutely mint condition – as is the house for a change 😉
Select cycle, shut door, pump pulses a few times and empties well, then all 6 prog lights flash and a constant beeping sound, have to turn off to reset machine.
Checked base for water – clean as a whistle ??
Usual lack of Miele info around so here I am again.
as you say all manual says is check pump and if it fails ring miele
i would look at it in this way
if machine pumps then fills a bit then stops look for a fill problem like the bosch impellor jug ( assume miele will be using a similar system now) if not i assume machine is doing a self check that will include thermistors etc so dig about. try pouring hot water inside first. long shot but it will alter resistance of ntc so if it works for longer you have found it
cant be lot of help as its miele have had my fair share of faults but wow is it a good feeling when you cure them
