Miele G1173Vi Dishwasher alarm
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele G1173Vi Dishwasher alarm
  • #76152
    larry
    Hi just wondering if theres a miele expert out there somewhere who can help with this dishwasher when you select a programme the drain pump comes on and so does the alarm and doesn’t stop.Theres no leaks underneath ive cleaned the sump out.All the programme lights are flashing also don’t know if there are fault codes for these machines any help would be great thanks Larry.
    #397404
    gadgetdad
    Re: Miele G1173Vi Dishwasher alarm
    Hi Larry, did you resolve this problem ? I have the same error on a job.
    cheers
    #397405
    larry
    Hi yes the pressure switch was all blocked up cleaned it out and away it went.
    #397406
    gadgetdad
    I said to the customer, Im not sure it knows its empty – thought pressure switch but didnt want to rip apart her bespoke kitchen without at least a good guess.
    Is it a standard diaphragm type switch ? where is it located in the machine ?
    Thanks for your help
    #397407
    larry
    its right underneath by pump best to put machine on its back outside if poss
