Miele G1182SCVi (D/W)
  • #100015
    rocker
    The dishwasher fills with water and circulating motor runs , but after around 4 to 5 mins it aborts and the 6 lights all flash, and audible sound…I have taken out the cover off pump check pump spins freely also checked the non return valve.. cheers John
    #478901
    does it stop filling ?
    this may help
    https://www.manualslib.com/manual/801663/Miele-G1000.html
    #478902
    rocker
    Hi Dave, it does stop filling ..then aborts..John
    #478903
    Hollytree_Technical
    With these dishwashers it is quite common for the pressure switch (6996821) on the side of the motor to fail, it is 2 changeover switches in one unit, when the machine starts and as it first fills it looks to check that both of the switchs are in the empty position, once full with the pump running then it will be looking to check that they have both switched over to the full position.
    I don’t know for certain that that will be your problem but in my experiance may be a good place to start.
    Jem
    #478904
    Hollytree_Technical wrote:With these dishwashers it is quite common for the pressure switch (6996821) on the side of the motor to fail, it is 2 changeover switches in one unit, when the machine starts and as it first fills it looks to check that both of the switchs are in the empty position, once full with the pump running then it will be looking to check that they have both switched over to the full position.
    Jem
    agree Jem had a few of these fail
    also you could check for debris in the main motor impellor
    rocker
    Thanks to both of you gents, for your advice..John
