Miele G1222SC Dishwasher
  • #91367
    dunston
    F14 Error.
    Will fill, wash motor starts then stops. continues to do this for 2 minutes then faults.
    Seen a couple of posts with this fault.
    Has any successfully fixed?
    #447851
    Seamy
    Re: Miele G1222SC Dishwasher
    Possibly the wash motor impellor has blockage in it, not putting up the correct water pressure, thus showing fault.
    #447852
    if not a blocked impellor then its the pressure switch clipped onto the side of the wash pump. Very common failure. often for leaks and trips as well.
    #447853
    dunston
    Seamy spot on with his diagnoses. Pieces of plastic in the wash impeller.
