Have checked machine for water fill/level switch+ heater element–all OK.
The machine fills,starts to wash then the wash motor cuts in and out at regular intervals for 5-10 mins before F14 flashes up? Any ideas?
Most likely something fouling the impellor of the circulation pump, you get this after it fills & motor starts, runs for a while but not enough pressusre to keep pressure switch contacts closed. Good news is its easilly repairable, pump splits handy enough.
