Miele G1232SC – F40
Viewing 1 post (of 1 total)
  • #76472
    Hollytree_Technical
    Hi all
    Can some one confirm whether or not this set of error codes is correct for this dishwasher.
    I have been told that it has been getting stuck in mid cycle for a while and that now this error is coming up, although it heats perfectly (apparently – I haven’t seen the machine yet) I will be checking out the insulation resistance etc on it (Suspicious that insulation breakdown on the heater may be the cause and will check that first unless you can advise different) but would appreciate any info on the error codes etc before I go as I don’t often see Miele dishwashers in these parts.
    Jem
