Miele G1270 Dishwasher F14 pulsing problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele G1270 Dishwasher F14 pulsing problem
  • #65005
    myfil
    We have been trying to sort out a Miele G1270 SCVI Dishwasher that was showing F14. I know the faults associated with F14, so I cleaned out the pump and non-return valve and tested the machine. The water level is OK, just a trifle high maybe, halfway up the filter handle. The washing pressure seems fine, The pumpout is OK. But when the wash starts, the wash pump is cycling – i.e. turning on and off. On for a few seconds then off for about ten.
    Can anyone shed any light on this?
    Many thanks
    Mike
    #358773
    Seamy
    Re: Miele G1270 Dishwasher F14 pulsing problem
    F14, Water intake fault.Heater pressure switch not activated.
    The program is interrupted and the drain pump is operated. The display shows the message Technical fault code F14 – Call Service Dept. The buzzer is activated for 2 minutes. With the circulation pump operating after a water intake step, the heater pressure switch is checked to ensure that sufficient water pressure exists in the wash water circuit. For this the heater relay must have been activated.
    Cause:
    Heater pressure switch B1/13 defective.
    Remedy:
    1. Check the heater pressure switch.
    2. Check the connection plug and wiring harness.
    3. Replace the heater pressure switch, if necessary.
    Cause:
    Circulation pump inoperative. Circulation pressure too low (no pressure at heater pressure switch). Pump may be blocked by foreign objects.
    Remedy:
    1. Check the circulation pump for foreign objects.
    2. Check the circulation pump capacitor.
    3. Replace the circulation pump, if necessary.
    Cause:
    Foreign objects in heater pressure switch.
    Remedy:
    Replace the heater pressure switch.
    Cause:
    Flow meter B3/4 defective (incorrect water quantity registered).
    Remedy:
    1. Check that the plate with the reed switch on flow meter B3/4 is seated correctly.
    2. Check that the reed switch connection plug is seated correctly.
    3. Replace the reed switch, if necessary.
    4. Check the control lead from the electronic to flow meter B3/4.
    5. Remove the water inlet mixer and replace if necessary.
    Cause:
    Circulation pump defective.
    Remedy:
    1. Check the circulation pump power supply.
    3. Replace the circulation pump.
    Cause:
    Circulation pump winding overheated; winding protection has cut out.
    Remedy:
    Cause:
    After a water intake step, heater pressure switch B1/13 has not opened switching steps 11–12 and 21–22. This starts the anti-stiction routine.
    Remedy:
    Cause:
    Motor capacitor defective.
    Remedy:
    Check the motor capacitor and replace it if necessary.
    Cause:
    Contacts on heater pressure switch B1/13 short-circuited. Contamination on the plug of the heater wiring harness and a conductive connection between the plugs and the main harness causes a short circuit to the contacts.
    Remedy:
    1. Replace the heater wiring harness.
    2. Replace heater pressure switch B1/13.
    3. Reconnect the two individual plugs from the main harness (AMP 6.3 x 0.8 ) and apply new insulation sleeves. Do not interchange the plugs.
    #358774
    washermanuk
    Hi matey had one doing the same? found plastic wrapper caught in the end of the circ pump!
