Miele G1270SCVI
  • #82834
    kentapplianceworld
    Looking for a Miele fill pipe from the circ pump to the top of the dishwasher, have tried connect and qualtex but don’t do that part!!!!
    Anyone know any more website or supplies that sell Miele parts
    #420935
    Re: Miele G1270SCVI
    Many Miele parts are Miele only.
    don
    Re: Miele G1270SCVI
    I can’t find your model number in full, there is a G1270 though. Can you recheck and post up please.
    Don
    #420937
    kentapplianceworld
    Re: Miele G1270SCVI
    This is the tag in the machine
    #420938
    don
    Re: Miele G1270SCVI
    Two different versions of this machine, yours with SCVI is not listed 😕
    Looks like both versions share the same internal pipework though. Can you let me know from the enclosed drawing which position number you are after.
    As an aside the majority of Miele parts have the part number marked on them.
    Don
    #420939
    Re: Miele G1270SCVI
    if its the smaller of the 2 you need, be prepared for a £100 odd cost! the rubber mouldings on the pump end of these going rotten is a common Miele problem and often only show up after you have disturbed them by removing the circ pump so I always warn customers of the consequences before starting work as I sure would not want to foot the bill for those.
    #420940
    kentapplianceworld
    Re: Miele G1270SCVI
    Don it’s 140
    #420941
    Re: Miele G1270SCVI
    kentapplianceworld wrote:Don it’s 140
    if you are changing it because the rubber on the end has rotted, would suggest you take a good look at the thicker one next to it too, usually if one has gone the other is in a similar state. and, as warned, that part is not cheap! part number for the thinner one (140) is 6001202
    #420942
    kentapplianceworld
    Re: Miele G1270SCVI
    To get the part from Miele its £97 and connect £92.
