I have got this dishwasher which is leaking, i have tracked it down to a small drip coming from between the wash motor and the impeller chamber which also holds the heater. i can ony imagine that the seal between the two is leaking, my question is can you seperate the chamber from the pump to replace the seal or is it one part, also some part numbers would be helpfull. Many thanks Andy
