miele g2570 d/w
  • #55957
    mike100
    got stone out of pump showing f13. cant get rid of fault code and dont now what it means. any help on this one please.
    mike
    #325737
    boselecta
    hi
    f13 is “Water intake fault at end of cycle”.
    #325738
    washermanuk
    Re: miele g2570 d/w
    3.11 Fault code F13
    Fault code F13: Water intake fault at end of step.
    The programme is interrupted and the drain pump is operated. The Inlet / Drain LED flashes. The fault will be indicated in the display or via LEDs. After approx. 2 – 4 min, the buzzer is activated for 2 min.
    On models with software version ID 769, the buzzer is activated continuously until the appliance is switched off.
    Background information: This fault is registered when the desired number of pulses, which varies depending on programme, has not been detected within a certain given time (max. 4 min) during the water intake in programme phases pre-wash, main wash, interim rinse and final rinse.
    If the selected programme starts with softener flushing, the fault check is carried out sooner. If the fault is registered, the selected programme is cancelled after 30 s and the fault is indicated.
    Cause
    On-site water supply not in order: Flow pressure too low.
    Remedy
    The on-site water supply should be checked by a specialist.
    Cause
    Water inlet valve defective.
    Remedy
    Check the water inlet valve and exchange it if necessary.
    Cause
    The flow meter B3/4 is providing too few pulses.
    Remedy
    Check the WPS (WaterProof System) valve Y2 (filter, restrictor disc).
    Remove the left side panel, see Side panel removal.
    Check that the plate with the reed switch on the flow meter B3/4 is seated correctly.
    Check that the reed switch connection plug is seated correctly.
    Exchange the reed switch if necessary.
    Check the control lead from the electronic unit to the flow meter B3/4.
    Exchange the water inlet mixer if necessary.
    Cause
    Water flow pressure at stopcock less than 1 bar.
    Remedy
    Check the water intake.
    If voltage is present at the electronic unit for the solenoid valve, check the solenoid valve Y2 leads for continuity.
    Check the filter at WPS (WaterProof System) valve Y2.
    Cause
    Filter in WPS (WaterProof System) clogged.
    Remedy
    Disconnect the dishwasher from the mains.
    Close the stopcock.
    Unscrew the WaterProof System from the stopcock.
    Remove the washer from the threaded union.
    Remove the filter with pointed pliers.
    Clean or exchange the filter as necessary
    hope this helps?
