A google search relates it to a drain pump fault or blockage? But I assume it drains ok. Does the circulation motor kick in when it’s filled to the correct level?
Would guess theres something stuck in wash pump impellor, appliance starts pump, but not sufficient water pressure is registered on the high pressure switch.
