Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Miele G4203SC tripping electrics
- This topic has 9 replies, 3 voices, and was last updated 4 years, 11 months ago by
andrew1875.
May 8, 2021 at 10:29 am #99518
andrew1875
ParticipantMiele G4203SC is tripping electrics.
Its just under 3 years old, so outside the 2 year warranty.
No fault codes showing
trips electrics approx 5 minutes after starting up. when I open the door, its full of cold water. up until yesterday, used 2 times a day with no issues.
I’ve removed and cleaned the filter, drain pump and non return valve.
1/ Any ideas what the most likely problem is?
2/ Is it worth getting Miele to repair on a 3 year old machine? or am I just throwing good money after bad.? previous Miele dishwasher lasted 11 years & washing machine currently on 15+ years
Thanks in advance
Andrew
May 8, 2021 at 12:02 pm #476726tubafan
ParticipantI’d say the most likely candidate is the heater. As for question two, how much a Miele charging to fix?
May 8, 2021 at 12:30 pm #476727andrew1875
ParticipantMiele want £249 as a fixed price repair.
The alternative would be something like the Siemens IQ300 SN236W03MG which is £549 at John Lewis with a 5 year guarantee.
If the Miele was 5 years old, i would lean towards replacing it, but at 3 years it still seems young [h=1][/h]
May 8, 2021 at 4:53 pm #476728electrofix
Moderatorthe heater is £85 from Miele
could be a heater or a leak
DaveMay 8, 2021 at 4:59 pm #476729andrew1875
ParticipantThanks Dave / Tubafan,
In general – do you think the miele is worth saving? Our last one lasted well
May 8, 2021 at 7:58 pm #476730electrofix
Moderatordespite the problems the miele build quality exeeds the siemans
i would say its worth saving. really depends what the fault is. I had one tripping and it ended up being a hairline crack in the stainless tub. She called miele out to confirn and they gave her a 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} discount despite being 5 years old
DaveMay 10, 2021 at 7:50 am #476731andrew1875
ParticipantThanks Dave. I’ll go with the fixed price repair from miele
May 12, 2021 at 10:23 am #476732andrew1875
ParticipantMiele booked for a fixed price repair on Monday & arrived this morning.
As Dave thought, it was the heater element.
Complete pump unit was replaced, and also he added a film around the pipes which he says is a Miele recommendation.
Absolutely delighted with the service from Miele
May 12, 2021 at 11:47 am #476733electrofix
Moderator“film around the pipes”
interesting wonder what thats for
glad you got it sorted
May 12, 2021 at 12:19 pm #476734andrew1875
Participanthe left the service sheet for the film
its 8 pages, but :
“Reason : if the circulation pump or feed pipes are replaced during service work, protective film must be attached after the new parts are installed. This precautionary measure should provide additional protection against moisture in the base area”
ps thanks for the help & diagnosis
