Miele G4263 SCVi Dead
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Miele G4263 SCVi Dead
  • #97303
    chris_yorks
    We have a Miele G4263 SCVi which had a major flood into the drip tray – just the drip tray but lots of water from the discharge pipe (repaired now).
    This caused arcing on the heater relay small control board module which has now been replaced.
    The display at the top of the door is now dead – no response from the buttons, no leds are lit etc.
    If we lift the float, the pump still runs so there is some control voltage present.
    I am looking for inspiration or a wiring diagram if possible – or some pointers from others here
    Many thanks for looking at this post.
    #467013
    well the fact its dead would mean the forst place to start is the main power board
    manuals and wiring are hard to get for miele you could search manualslib to see if there is any info that may help
    chris_yorks
    Thanks Dave,
    I trawled manualslib without success.
    I’m assuming the main board will be in the upper part of the door?
    Cheers
    #467015
    you will prob find similarities in this one
    https://www.manualslib.com/manual/1333124/Miele-G-4205.html?page=21#manual
    chris_yorks
    Brilliant – thank you I will have a good read of this one
