Miele G560W Leaking
  • #27740
    monkey
    Hi can anyone help with this dishwasher
    It is leaking on the righthand side were the fill pipe connects to a plastic tank.The only problem is the tank is up the side of the casing and I cannot see how you get into it, has the casing is pop riveted together and spot welded.
    please help.
    #215421
    Seamy
    Re: Miele G560W Leaking
    Take off top cover, see screws at front & back, think the side panels should come off then, access to fill chamber is on left hand side.
    #215422
    monkey
    the front and back and side panels are all joined together.I dont suppose you have a service manual
    #215423
    No, they’re not. Follow the advice given.
    fidder
    The only way is to extract the tank through the top….cut away foam filling and it will eventually pull out. Trev
    #215425
    msappliance
    miele d/w are known for the water inlet inside the tank to come loose, make sure this is tight half a turn is enough, sorry for the late reply.
