MIELE G638 INLET/DRAIN LIGHT
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries MIELE G638 INLET/DRAIN LIGHT
  • #34017
    Minge
    HI
    I AM HAVING PROBLEMS WITH THIS MIELE DISHWASHER … IT FILLS AND DRAINS OK AND THERE ARE NO OBVIOUS BLOCKAGES ETC….
    WHEN YOU SELECT THE PROGRAMME ONCE IT FILLS AND THE DETERGENT DISENSER OPENS THE INLET/DRAIN LIGHT WILL COME ON AND STOP THE CYCLE..
    THE ELEMENT TESTS OK… COULDPOSSIBLY BE A NTC SENSOR/STAT OR SOMETHING? PLEASE ADVICE!
    MANY THANKS.
    #240895
    gegsy
    Re: MIELE G638 INLET/DRAIN LIGHT
    Inlet/outlet lamp 😕 Either a base full of water or a fill timeout which could be low water pressure or faulty flow meter (if fitted) IMO
    qas
    Another likely cause for this one is the pressure switch on the wash pump. If it is not activated at this point, then there is not enough water for heating and you get this error.
    Most likely fault is rubbish in the wash pump, otherwise faulty pressure switch
