MIELE G638 Overfilling
  • #40647
    monkey
    Hi Guys
    I have asked you about this before. I have still not managed to fix it.
    It fills up and starts to wash, but the water does not cut off, I have noticed it as 2 pressure switches. Can you help?
    #267115
    Re: MIELE G638 Overfilling
    Well, one of the two switches is either blocked or failed, surely? If I remember correctly, one is a low pressure level switch, the other is a high pressure one spurred off the circulation pump. The low pressure one starts the pump, the high pressure one stops the fill. The old Philips ones use to use a similar system – tried to pressurise the little one and went very red in the face before I figured it out.
    monkey
    thanks.
    I called back and checked pressure switches, they seem be ok. what I have noticed is that it starts to fill as soon as you power the dishwasher up.
