Miele g638 plus Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Miele g638 plus This topic has 7 replies, 3 voices, and was last updated 19 years, 3 months ago by LittleMan. Viewing 8 posts - 1 through 8 (of 8 total) Author Posts December 13, 2006 at 7:15 pm #23353 LittleManParticipant Hi Can any one tell me why after a few seconds of starting this machine starts , inlet/outlet flashes 5 times stays on then starts flashing again can you help please les December 13, 2006 at 9:54 pm #197841 msapplianceParticipant Re: Miele g638 plus Normally this fault is not filling quick enough. try checking fill filters, not syphoning and good water pressure. December 14, 2006 at 4:53 pm #197842 LittleManParticipant Re: Miele g638 plus Hi this machine goes into drain then for a split second trys to fill then starts flashing and it is only for a split second HELP Les December 14, 2006 at 6:52 pm #197843 msapplianceParticipant Re: Miele g638 plus can you select spin or rinse on its own? December 14, 2006 at 6:57 pm #197844 msapplianceParticipant Re: Miele g638 plus ignor last comment just noticed its a d/w will try to get back 2 u December 14, 2006 at 7:12 pm #197845 msapplianceParticipant Re: Miele g638 plus ok try this, strip down appliance filters make sure circ motor is free, you can turn the impeller here. If stuck motor faulty if free change pressure switch had this fault before just making sure. December 15, 2006 at 12:23 am #197846 eastlmarkModerator Re: Miele g638 plus would check for water in the drip tray first. December 16, 2006 at 8:31 pm #197847 msapplianceParticipant Re: Miele g638 plus If had water in drip tray i would expect drain pump to aways run. Author Posts Viewing 8 posts - 1 through 8 (of 8 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
