Miele G638I plus dishwasher
  • #45560
    Galway
    hi this machine has the inlet/drain light flashing cleared stuff from pump and thought it was sorted.started programme and it pumped out then took in water and started to wash for about 10 sec then stop then wash again and repeated this for about 5 min then the inlet/drain light flashes .have checked base and it is dry .i have a test programme for a different model but it wont do it for this model has anyone got one for this or am i missing something.
    thanks
    #286141
    Seamy
    Re: Miele G638I plus dishwasher
    Pressure switch not getting activated after motor starts. Normally something blocked in the impellor of the pump. You can split it & check quite easilly. Could be duff pressure sw’ either.
    #286142
    Galway
    checked the drain pump and cleared it or is it the circulation pump? or could a slow inlet valve cause this . water coming in but does not sound as loud as other d/w.
    #286143
    Seamy
    Circulation pump, slow inlet water pressure would also cause exact same problem, as if not enough water has filled when circulation motor starts there won’t be enough water pressure to activate pressure sw’ thus causing machine to go into fault condition.
    💡 check filters in inlet hose
    #286144
    Galway
    thanks for replies checked filters ok.checked the pressure switch and it does not click when you blow into it .should it click or is it caput?thanks
    #286145
    Seamy
    You can put a meter on the terminals, switches should change over when you blow in to it
    #286146
    Galway
    ok will do.do you have to put d/w on its back to take bottom tray off to split motor to check propellors?
    #286147
    philfish
    i do but remember to take 2 x t20 out back plate which hold circulation pump in 1st always forgot to do that!! lol
    #286148
    Galway wrote:thanks for replies checked filters ok.checked the pressure switch and it does not click when you blow into it .should it click or is it caput?thanks
    its a high pressure swtich so need a syringe to operate it, unless you have a lot of puff it wont click by blowing.
    #286149
    Seamy
    I must have good puff, then us Irish are made differently 😀 !
    You could leave pressure sw’ in situ, take off cable connection & meter it when motor starts 💡
    #286150
    IME the click of this switch is so loud you can hear it!
    #286151
    Galway
    I ordered a new pressure switch (which you could hear click when you blow in it ) and the problem is solved !
    Thanks for your help 😀
