Miele G641 Dishwasher
  • #36333
    mike100
    Door springs seem to be very strong. Customer complains that unless lower basket full door will close and makes using upper basket difficult.
    Is there any adjustment to the springs?
    Any past experience welcomed.
    Mike
    #250632
    Seamy
    Re: Miele G641 Dishwasher
    Some Miele dishwashers have a screw adjuster at top of machine, when door is open. You may have to lift seal to see it, from memory anti clockwise to lessen tension, clockwise to increase tension.
    Other frestanding Miele dishwashers, take off top panel & side panels, spring can be hooked into diferent positions.
    Door should sit at 45 degrees without closing or falling open when tension is correct.
    #250633
    mike100
    thanks alot Seamy, exactlty as you described with spring adjustments at top. happy customer
    mike
