Miele G646 SC
  • #32811
    ChrisR
    Hi guys.
    Don`t normally get involved with Miele but had no choice with this one.
    Inlet/Outlet light flashes.
    Machine fills and empties ok but when put on programme it fills to level then stops,circulation pump(i assume ) operates for a few seconds then inlet/outlet starts flashing and machine goes off.
    Have checked pump and valve but everything seems ok.
    Any ideas?. 😕
    #236468
    gegsy
    Re: Miele G646 SC
    Have you checked the sump and filters?
    Had a similar one where they had been washing jam jars to recycle and the labels had become detached and gone into a pulp clogging the filter area.
    clayside
    Re: Miele G646 SC
    seems like machine is not sensing output pressure form circ pump. Make sure circ pump impeller is clear also had pressure switch blocked/faulty ( mounted on pump ).
    clayside
    #236470
    Seamy
    Re: Miele G646 SC
    Clayside might just have hit nail on head about machine not sensing pressure from circulation but from experience its more likely to be a fill time out.
    Check inlet hose filter, inlet hose for kinks, remove top & left hand side panel & check water is coming into fill chamber, some of these 646’s have a flowmeter on inlet hose.
    Most of them monitor water level over a short period of time & if correct level isn’t achieved fault is shown.
    Circulation pump is easilly removed if needed, check impellors for obstruction.
    #236471
    ChrisR
    Re: Miele G646 SC
    Thanks guys.
    Circ pump seems favourite as water flows in normally and water discharge is ok.
    Heres hoping 🙂 .
