miele g646 sci plus
  • #44857
    timjam
    hi , i have this booked in for next week, cust claims water is coming out the the therm vent on the right side of dishasher, has anyone come across this prob ? iam not that familar with miele d/ws, thamks ….
    #282601
    DRH
    there is a drain pipe from the drying fan to the combi dispenser in the door, it gets blocked.
    split the door and give it a clean out. job done.
    #282602
    timjam
    Re: miele g646 sci plus
    thanks ….
    #282603
    Steven
    I hope you dont mind I am going to jump in on this post and ask about a fault on the same model G646 sc I have of not heating?
    Fills and washes to correct level, pressure valve operates so has enough pressure of water in the system, but does not heat.
    It has a relay contactor inline with the heater, the relay has no supply to it at the point it should be heating it appears to be supplied direct from pcb.
    Any one come across this fault, could it be a pcb fault or is there something else iam missing?
    Steven
    #282604
    Seamy
    Had some with burnt connection on board supplying heter relays.
