Miele G646s D/w
  • #46631
    S1MON
    Got a little problem with this
    Will drain, fill for approx 1-2 secs then the inlet/drain light flashes.
    Ive checked the usual, motor + high pressure switch fine, draining fine etc.
    Now the sump was blocked with crap I blowed that out, got it too work once, then reset and it did the same.
    I changed the non-return valve to but too no avail, any ideas?
    Is it timing out or is the something not sending the right signal back too the pcb?
    #290263
    philfish
    Re: Miele G646s D/w
    Could not be recieving the signal from reed switch on the flowmeter,faulty reed switch sticky flowmeter. not sure of model but flow meter either in the matrix on the side or its in a little black or white box at the front bottom right hand side of the machine if that makes any sense!
    hth phil.
    #290264
    S1MON
    ok ill have a look
