Re: Miele G646SC Dishwasher
Overflow switch or float switch in machine base prevents water coming in if made.
Check for water in base or sticking switch, also check for inlet filters blocked.
Circuit diagram of dishwasher is located behind controller.
Float switch is listed B8/3 in circuit diagram, overflow switch is B1/2 in series with inlet valve.
You can use your meter to check for 240V to Y2 (inlet valve) at control board, there should be 240V on those connections when programme starts.
Fill time can be extended if theres a water pressure issue.
