Machine has a leak into the base, trouble is I cant get it to fill,
as the inlet/drain light comes on and it starts pumping. Take it
I need to reset this somehow, so can see where leak is.
Any one know how?
I have removed the base, removed and reconected the inlet valve from the tap, which often resets these things on other makes.
trouble is machine will not fill, so cant hunt for the leak
machine starts, but after about 10 secs, inlet/outlet
light comes on and machine drain pump turns on
I was thinking that maybe it had to have the electronics
reset somehow?
is the circ pump running for that initial 10 secs? If not it may be siezed and causing the flashing light as the high pressure pressure switch is not revieving its signal.
If not then you may be right about re setting its, its a complex proceedure, one of the miele experts might be able to explain it better.
