Ok, have a Miele G646 SC Plus for repair.
The fault was reported as being leaking from the bottom somewhere, there is signs of leakage on the base tray of the machine, but there is no leak there now, all the hoses are ok, circ pump no signs of leakage, pressure switches seem ok, But the problem that ive seen is this, the drain pump runs all the time, even when in stop mode, when you start the program off, say 50C normal, the pump still runs, takes in no water then eventualy the inlet/outlet light flashes, but the drain pump still runs.
Ive checked the float switch and thats working fine.
Any ideas from here on ?
