Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Miele G653 SCVI PLUS dishwasher
- This topic has 8 replies, 4 voices, and was last updated 7 years, 11 months ago by
boselecta.
April 14, 2018 at 9:21 am #93719
boselecta
ParticipantHi Guys,
I fitted the motor seal / impeller kit two weeks ago as it was leaking into the base.
Just been called back as dishwasher now drains out continuously and the inlet/ drain light comes on after about 40 seconds.
There is no water in the base and I’ve checked the motor impeller again for blockages.
The dishwasher does not seem to attempt to take in any water.
This is the older model with the pressure switch and not the one with the reed switch on the water tank.
Anyone got any ideas as dont want to have to refund the customer!?
thanks
April 14, 2018 at 9:46 am #455348electrofix
ModeratorRe: Miele G653 SCVI PLUS dishwasher
well it obviously thinks its still full of water
have you checked the float in case its gone faulty ?
April 14, 2018 at 3:22 pm #455349boselecta
ParticipantRe: Miele G653 SCVI PLUS dishwasher
Thanks for replying Dave, yes i have checked the float switch and tried disconnecting it, still the same, 🙁
April 14, 2018 at 3:40 pm #455350electrofix
does it start pumping the minute you turn it on or only when you set a programme?
April 14, 2018 at 4:18 pm #455351boselecta
Only when a program is selected and the door is shut, then after 40 seconds the drain / inlet light comes on
April 14, 2018 at 4:53 pm #455352electrofix
doing a quick web search found this
this will prob be the American machine but I cant see them changing much so the info may well transfer
April 15, 2018 at 10:54 am #455353boselecta
Thanks dave
April 17, 2018 at 7:20 am #455354eastlmark
does that one have a second pressure switch under the door rh side? might be worth looking at if so, pressure chamber for that one is under the lower spray arm mount.
Also has it got an aquastop valve? if so the connector for the remote valve is in a vulnerable position on the right hand side below the door hinge area, it often gets leaked on by a slight drip from the solenoid that is on the rh air break, shorts out and gooses the electronic so a major issue if so. If the plug there is burnt then suspect that is the case.April 19, 2018 at 6:08 am #455355chitts
Broken wire in door harness? Had same fault and that was the cause.
