Turn on, Select a prog, close the door – nothing! (other then i think i can hear a couple of quiet clicks from control panel) after about 15-20 secs the Inlet/Drain light flashes continuously. There’s no water in the base, Ive checked the filter in the aquastop, Water pressures fine, Checked the non return valve etc – all fine. I’m now thinking it must be the aquastop itself. Would i be along the right lines.
Ollie.
sounds like the aquastop matey? have you checked valve with a meter?
you can do this underneath machine thin black cable with small plug on the end with brown and blue wires!!! or the float microswitch might be worth checking? get a few burnt out ones!!!
hope this helps Brian
