Miele G660-2
  • #17820
    Dave_Conway
    Can anyone help with parts numbers etc for the upper (roof) spray arm and fixings please.
    I think there is a kit for these ?
    TIA
    #176521
    qas
    Re: Miele G660-2
    My information doesn’t show a kit, but the following part numbers may help
    2599491 – Spray arm SC DRM31/27
    3521352 – Spray arm retainer SC
    2239300 – Spray arm
    3521362 – Spray arm retainer
    Not sure exactly what the codes mean, but the SC version is about twice the price – could be stainless rather than plastic
    #176522
    presser
    Re: Miele G660-2
    Spray arm top:4803194
    Locknut :4802013(my lot generally replace this at the same time)
    There you go,
    HTH
    #176523
    Dave_Conway
    Re: Miele G660-2
    Thanks chaps 😀
    Are there two versions then ?
    Cheers
    #176524
    presser
    Re: Miele G660-2
    Dave_Conway wrote:Thanks chaps 😀
    Cheers
    Well spotted 😳 If the machine has a single feed pipe (ie the middle spray arm is fed from the roof via a funnel) then see qas’s post.If on the other hand it has two feed pipe’s(middle spray arm fed via the back wall through its own tube) then the plaudits are all mine 8) .
    #176525
    presser
    Re: Miele G660-2
    The SC version is exactly that,its only for the SC version.The SC non SC split is also identified by serial number.
    #176526
    Dave_Conway
    Re: Miele G660-2
    Thanks, the customer doesn’t know how to tell 🙄 so I’ve asked him to send a picture.
    Presumably the spray arm will have a hole straight through the centre if the middle spray arm is supplied from the roof inlet ?
    #176527
    qas
    Re: Miele G660-2
    Thanks, I didn’t think to relate the SC to the model variant. I’ve learnt something here too 🙂
    Steve
    #176528
    presser
    Re: Miele G660-2
    Dave_Conway wrote:Thanks, the customer doesn’t know how to tell 🙄 so I’ve asked him to send a picture.
    Yep.
    #176529
    Dave_Conway
    Re: Miele G660-2
    Cheers :tup:
