Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › miele g679sc program lights flashing
- This topic has 6 replies, 3 voices, and was last updated 18 years, 1 month ago by
smart.
February 12, 2008 at 11:37 am #34541
smart
Participanti’ve been out to a miele g679sc-vi-2 dishwasher. the program lights 1-5 are all flashing. found the flood protection had been activated due to a leak from the flow meter. i’ve replaced the flow meter but the lights are still flashing. has anybody any idea’s? or better still any fault codes
February 12, 2008 at 6:10 pm #243072Seamy
ParticipantRe: miele g679sc program lights flashing
Have you fitted a new Reed Switch or just taken old one out & put it back?
I’ve found its sometimes difficult to get then seated correctly for the magnet to move the switch.
Also check you haven’t pulled the cable off the Electronic board.
If Electronic doesn’t receive any pulse from reed sw’ it usually gives an Inlet Fault.
Is this what you get?February 13, 2008 at 10:12 am #243073smart
HAVE REPLACED FOR A NEW AS HAVE TRIED TO REPAIR ON PREVIOUS APPLIANCES AND FOUND IT ONLY WORKED FRO A WEEK. CONNECTIONS OK ON MODULE. APPLIANCE DOESN’T EVEN START. SWITCHES ON OK BUT SOON AS YOU TRY TO SELECT A PROGRAM THATS WHEN THE LIGHTS START TO FLASH. DONT EVEN GET ENOUGH TIME TO CLOSE THE DOOR.
February 13, 2008 at 1:21 pm #243074Seamy
Well its not a water fill problem. Do you know how to get into service mode?
February 13, 2008 at 5:40 pm #243075philfish
Is the float switch stuck? just a thought.
February 13, 2008 at 9:09 pm #243076smart
DON’T KNOW HOW TO ENTER SERVICE MODE, COULD ONLY GET INTO WATER HARDNESS LEVEL. TRIED COMBINATIONS OF BUTTONS ASWELL. FLOAT AND FLOAT SWITCH OK. I’M PUZZLED
April 21, 2008 at 3:31 pm #243077smart
just spoke to customer. they had miele out and as i suspected i had solved the problem, it just needed a combination of buttons to be pressed to clear fault (cust couldn’t tell me what buttons). 😡 gutted as i tried loads of combinations but obvousley not the correct ones. thanks for any suggestions. one to look out for
