Miele G694SC plus 3
  • #29784
    Simon46
    Got to go and look at this one tomorrow. Customer reports that a light is flashing check water/drain i think. He seems to think it isnt filling. Where do i start on this one please? Is it flood protection?It is my first.
    Regards
    Simon
    #224724
    Seamy
    Re: Miele G694SC plus 3
    Check water in take 1st . Theres a float sw in base of this machine, to get access to machine take off top & sides. Check flowmeter (reed switch) you should wheel move around when its filling. Also check for level switch on curculation pump can give inlet fault too if it doesn’t register pressure.
    #224725
    Simon46
    Turns out it was a connector at the front RHS got wet. brown and blue wire rumnning to back (inlet valve?)hardwired it, no sign of a leak though. 10 degree forward lean on dishwasher is the only thing i can contribute it to. levelled will see.
    S.
