Miele G7702
  • #72081
    Hollytree_Technical
    Hi All
    Does anyone have a complete part number list for this machine please?
    Or can any one tell me if it is possible to get the shaft seal for the drain pump separately from the pump?
    Thank you
    Jem
    #383393
    Re: Miele G7702
    doubt it but does this help
    http://www.nettoparts.co.uk/shop/drain- … 1276p.html
    Hollytree_Technical
    Re: Miele G7702
    Yes that will certaintly make it more palatable for the customer – you don’t know where I can find the heating elements cheaper do you? I don’t know which element(s) it will need replacing yet but suspect that it is one of them that is causing the RCD to go, will have to find out which when there is not so much hot water pissing out of the bottom.
    Jem
    #383395
    Re: Miele G7702
    had a look and no cant see one
    but it could be the water leak causing the problem
