I have a miele G7762 dshwasher to look at, one of the faults is the salt light staying on. It is taking salt and washing fine, anyone know if there is a common problem and how does this DW measure salt level?
Don’t recognise that model number, check the water softener container at the bottom of dishwasher. On most Miele dishwashers theres a small reed switch, this is activated by a float which you should also see on the side of the water container, check that float is not stuck. The program can be set to not show salt led faults.
G7762 is a commercial dishwasher
As far as I can tell (using information for similar models) the recativation light comes on after a certain number of operations after reactivation, based on the hardness programmed into the machine.
The machine, when new, would have come with an installation booklet with the hardness table and setting instructions, so hopefully them owners stil have the book (unfortunately I am still trying to source information for this model, my local hospital is full of them as pan washers)
Thanks guys,
Will have a look this week when my back repairs itself 😯
Yes it’s in a care home, fixed a few faults before but not too sure how the salt light works. I know there is a seperate proramme to refill salt. There is zero chance of them having any info, all i get is “over there” sometime i fix the wrong fault!
Cheers
Graeme
