Re: miele g7859
found more lol 😉
After water intake, the heating level switch must switch. The query occurs 2 seconds over a length of 2 seconds in the following step. For target water measurements less than or equal to 1.1 gallons (4 liters) this fault monitoring is not active.
Cause
Heating level switch defective.
Remedy
Test the function of the circulation pump. See Service Mode 2, Description of Program Levels S21 to S24.
Check the connection plugs and wires.
Check the switch point of the heating level switch (2 seconds after circulation pump starts at nominal speed).
Check the connection hose to the circulation pump for obstructions.
