Got a bit of trouble with this machine.
Basically it sometimes finishes with clear water at the bottom ( check fill / drain light flashing ) and the height of this water is equal to the normal fill height so it has nothing to do with back filling. I of course have never got the machine to go wrong. Set on “normal” it has consistantly worked 4 times for me, fills, soap disp opens, heats, pumps out, refills, etc…….start to finish, but obviously not for the person who normally uses it. I`ve checked the outlet one way ball bearing valve, the cone gauze filter, there`s nothing in the impellor area of the pump, and it is plumbed out in to a waste disposal unit nozzel. The inside of the machine is well looked after.
Anyone got any suggestions please? Anything common I might have missed? Anything weird and wacky? Thanks.
