hi everyone does anyone know a way to test the reed switch on the water inlet pcb other than replacing it,or is there a way of by passing it to test if it is at fault.the inlet/drain light flashes as soon as the machine takes in water but it carries on filling and then nothing.any help much appreciated.
you cant bypass it because it needs to pulse to send a signal to the pcb
you can test reed switches with a multimeter and a magnet
only way you could bypass it is to solder 2 wires to a push switch and when machine start you push the switch on and off fast as you can, but reed has got to have failed o/c for this to work without removing it
