Miele gG1182 SCVi dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele gG1182 SCVi dishwasher
  • #94671
    DPDOM
    Hi Guys
    The dishwasher fails just after the heater relay clicks in a few minutes after circulating the water. Everything turns off for a few seconds then starts circulating again and as soon as the relay clicks it shuts down. afters several times all lights start flashing.
    I have tried a new pressure switch, Tested and cleaned the relay, checked the heater and made sure the circ pump is clear.
    Any help would be much appreciated.
    David
    #457967
    Re: Miele gG1182 SCVi dishwasher
    does sound a bit like the heater current is messing things up
    have you tried a different socket ?
    or put your meter on the mains in and watch the voltage as it fails
    Kentish
    Taken the wash motor out to check the impeller has no plastic wrapper debris in it?
    #457969
    DPDOM
    Yes I’ve tried the socket and checked the impeller. All seems fine.
    #457970
    Seamy
    There’s a high pressure switch near the circulation pump to protect heater getting supply if there’s not enough water , if circulation pump doesn’t put up enough pressure it won’t continue & throws up error code.
    Normally its because there’s a blockage in the impeller as previously stated.
    Could be fault with pressure switch, hoses, cable connection etc
    #457971
    DPDOM
    I know what you mean as I’ve had plenty with blocked impellors but this was clear and I tried a new pressure switch.
    It was more like the module was loosing power as soon as the relay clicked in.
    Customer has already ordered a new dishwasher so one less stress this week.
    Thanks All
    David
