Miele heat pump F066
Home Forums Trade Technical & Spare Parts Forums Miele heat pump F066
  • #101632
    oscar123
    All filters and heat exchanger clean.. even empty it switches off after 3/4 minutes flashing F066. Fault code indicates blocked filters or drum overloaded but definitely not the case with this dryer any ideas on other possible causes?
    #485492
    no model so cant see the works but early model used to give similar problems with damaged door seals
    oscar123
    Sorry Dave it is a TWF505WP. only around 3 years old 🙁
    #485494
    cant find anymore info apart from utube videos cleaning filters
    another site i found said it may be an air path leakage which could include door seal
    oscar123
    Thanks for your help Dave.. I usually have Miele tech help from a friend but he is away on holiday. 🙁
