miele heater
  • #71462
    suedehead1
    hi I dont see many Mieles round here it a W2653WPS,
    the heater is faulty.
    2 questions how do I change it it seems to be in with a couple ok
    spirex washers, and whats the part number please.
    #381109
    Re: miele heater
    And not even asked the price. :eeek:
    #381110
    Re: miele heater
    The heater seal is pulled out after removing the clips. Not sure of the part number.
    Bryan
    #381111
    Re: miele heater
    34 ML 01 from maddocks fit most Miele’s. Dont recognise this model number though so dont hold me to it.
    remove the clips (you get new ones with the heater) the drip shield and then ease it out. The rubber seal will give way easily but the heater may be scaled in and need a good tug, mole grips on the terminals usually work.
    I use a metal tube that will fit over the terminals to fit the new clips and drip cover with the aid of a hammer. Just note how far the old heater went in and that the ntc does not touch the element itself when you push it back in. clean the grey air bell next to the heater at the same time, common for them to block and cause heater problems.
    #381112
    suedehead1
    Re: miele heater
    thanks very much its the usual story hassling customer “when you coming” get me a price then once you have quoted no commitment they will be off to espares to buy one hope they forget to pull the plug out. its fur coat and no knickers.
    #381113
    suedehead1
    Re: miele heater
    thats not a great design a couple of spring clips holding the seal in just waiting for a phone call to say the kitchens flooded.
    #381114
    Re: miele heater
    suedehead1 wrote:thats not a great design a couple of spring clips holding the seal in just waiting for a phone call to say the kitchens flooded.
    but, bet you never see one pop out.
    Just wait till you do a condenser clean out on a Miele washer drier you will not believe how tentative the seal is in the tub.
