Re: Miele heating problem
Sorry, I meant the temp sensor. I’ve changed the temp sensor but it still has the same problem. The problem isn’t just that it overheats on normal wash programs but that it also heats on the cold-wash program, like the heater can’t be shut off. The water level is not too high.
I’m going over the technical diagram, I see the thermostat and something called a thermostop on the index sheet but I can’t see it on the main diagram so I’m assuming that these are components on either the power module or control module. I haven’t worked on too many fully electronic heating systems before 😳 .
