Miele HG01 40/79306491 6975SCPlus
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele HG01 40/79306491 6975SCPlus
  • #68429
    robbra
    Have the inlet/drain flashing. I cleared this by switching off at the mains and setting a new programme (not sure if this completely clears it). Cleaned inlet filter and non return valve. It now fills quickly and also drains well but no cycling pump.
    Is there a reset procedure and am I missing something else.
    Rob
    #371086
    Seamy
    Re: Miele HG01 40/79306491 6975SCPlus
    Check the cable to small P.C.B of the water counter, & also the seating of the P.C.B in regard to the magnet. If its not seated correctly the reed switch on P.C.B won’t pick up signal from magnet & thinks its not filled. Circulation pump motor could also be blocked up, its an easy job to split & check.
