Miele Industrial Washer WS5110 missing diagram
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele Industrial Washer WS5110 missing diagram
  • #24275
    Has arrived without diagram and has few wires in air (removed from connectors) :silent: . Model is WS5110 sn:1314.
    Most of wires at Miele are writen but those letters I couldn’t find on programmer, neither around (perhaps missing also one component :bang: ).
    So diagram is needed
    Thanks,
    Baron 8)
    #201380
    Seamy
    Re: Miele Industrial Washer WS5110 missing diagram
    Where is this “component” that is missing?
    is this a commercial machine?
    some machines arrive with the option of putting on a coin or token mechanism.. is this what it requires?
    #201381
    Machine I think is commercialized by proper dealer because is for 10Kg.
    Missing “component”(four wires) is in the back side, left to main timer….
    Seamy, thanks’ for your thoughts but I didn’t say from beginning that in this machine had worked two weeks one of so call “free self employment” :clown: .
    I don’t want to spoke about it; just he made lot of changes (wrong) until safety device from main power supply start to work. :angry4:
    Therefore I need diagram in order to verify all changes after him.
    Thanks’ anyway 8)
    #201382
    Seamy
    I don’t really know which component you refer to, i don’t have any info on the model mentioned, but if its any help on Miele commercial machines i’ve worked on have the option buttons next to the timer. Behind the timer near the back is a plug with option to connect a coin mechanism or token meter, there are certain links that need to be made for machine to work here.
    #201383
    Seamy, much appreciated your kindness for above… :tright:
    but only diagram :hmm: can help me to go forward…
    Baron 8)
    #201384
    fidder
    Have you managed to get diagram yet?…Trev
    #201385
    No, I didn’t received any diagram.
    #201386
    Have you removed front panel? often a diagram in a plastic wallett down inside somewhere. Forgive me if I am stating the obvious!
    #201387
    I know that.. like I’ve said before it was allready too much worked on it… so missing diagram
