Miele integrated fridge problem
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Miele integrated fridge problem
  • #95553
    woolentop
    We have a large Miele integrated fridge which worked perfectly for a number of years.
    Recently it has started freezing things, especially in the lower part, including the salad drawers.
    We have checked the drainage, pulled it out and hoovered the back, added extra plinth ventilation, but with no success!
    HELP! Many thanks, Sue
    #460724
    Tony R
    Hi Sue can you post the model and index number, to identify your exact unit.
    Tony.
    #460725
    woolentop
    Hi, sorry for the delay Tony, I’ve not been well.
    Model number is K9412i and I THINK the index number (is that a serial number?) is 82/96206770.
    We assumed it must be the thermostat and have looked for them online. However when my husband took off the front panel where the thermostat dial is, he could only see a circuit board, nothing that looked like the ‘
    Repair kit Temperature sensor’ available from Miele!
    #460726
    Tony R
    The index number should be located at the end of the model number an example is 20B-164, this is important for production period
    #460727
    woolentop
    The Index number is 20F 164
    #460728
    Tony R
    Checking the parts diagram, I would suggest a sensor failure, and would be the best place to start, you can obtain one on here, part number 9590206, this is a Liebherr part that will fit your unit.
